T3000 Webview graphic quick start
T3000 HVAC Drawer
This web-based tool allows users to create and visualize HVAC system drawings for buildings, to utilize data obtained from T3000 devices for rendering animated drawings.
The T3000 software can so some basic animation; for instance then fan can rotat and the damper open depending on the actua real time situaiton.
Nested graphics can be created, starting with a floor plan the various zones and systems can be linked from the overall view.
To get started, select a T3 controller in your system, then click the β€œGraphics” icon. Give each of the graphics you plan to build in the grid, then double click to head into a paricular graphic screen. Next upload a picture of a room as a background.
  • A sample floor plan
Each of the sub-graphics can have their own picture as well. Insert an element and then use β€œLink to an entry” to point to the other graphics. Enter the Label of the sub-image to complete the link.
Open the various pages in your system you can use the rudimentary built in T3000 webview to draw basic walls, ducts and son and populate them with the various IO of the system. If you have your own library and grapgics system you can also import your own drawings as bitmaps.
  • Air handler 1
You can link the real time IO by inserting an element and then click β€œLink with an entry”
You can link any IO or object from any controller in the system by referring to their user short 8char name (OUTTEMP) or the panelID, object name reference method (2IN1), both will work.
The drop down menu system will do its best to help you filter down to 144 VAR1 for instance, enter β€œ144VAR” and select it from the drop-down menu.
Once an entry has been linked you can click on the graphic screen to perform actions on the entry, such as changing the auto/manual mode, changing colors, fonts and so on.
  • Air Handler 2
After all the graphics are finished, click on the lock icon to lock it, All data is stored in the T3 controller and also in the *.prog file when you save it. Eventually we plan to get at these pages without T3000 from a regular browser or phone. We appreciate your feedback to make this systm better.
When building owners can load their graphics on a web browser, this will take Temco controls to the next level!
This is in fact a browser you see here in this graphics window but its operating from within T3000.exe. Next step go from the browser directly. Its very close.
So when you get the web browser graphics done, users can type in remote static IP :port and see the graphics remotely from another building. Would this require a password? Also on the local network, you would just type in the IP of the controller and be able to see the graphics. Would this require a password?
Yes, we are working towards that but we are extremely busy and need to hire more people asap. First step will be to get BBMD going so we can access an entire site from a single IP address, its long overdue. We will get there.
Thank you very much for your time spent on the system, keep the feedback coming.
