AQ configuration , protocol :modbus , baud rate: 115200 ,Default ID:254 ,I changed to ID=6 .
Connect PT12 and AQ to Nano RS485 main and click “discover” button , TB,PT12 and AQ are shown under local network tree , you can conveniently contol each device .
How to load AQ to default Factory mode .
Modbus poll wirte REG169=259 ,REG170=139,REG178=0 .
please download my detailed steps PDF file from the following link
Ok …good idea…
I was wondering if ordering one T3-LB and one more AQ could help to go further with other product and exclude some hardware problem with the nano and the AQ I have from here…
If you agree with this idea, could it be possible that the component I would ordered are configured and tested together by Spring before sending them to me.
I will put the focus on testing the Metz module with USB/rs485.
I can connect them directly to the raspberry PI and manage them from codesys softPLC or any modbus master software running on a computer.
I also bought a waveshare RS485 to ETH … will check if this can be configured to do the basic routing task from Modbus TCP to Modbus RTU…
I will keep you informed of the results
just be careful that not all RS485 to ETH devices/routers support ModbusTCP to ModbusRTU routing. Whatever router you buy must specifically support the Modbus routing.
good luck
I should have checked this before…
It seems that you are right, the RS485 to ETH I bought seems useless for modbus routing
The good news was that the USB RS485 is simpler as soon as you connect properly, it is working
I finally succeed to connect my Metz connect triac output module on the main subnet of nano.
I am able to drive them from the modbus poll but not from the control basic program .
So I worked more on the rasberry PI interface using Codesys with modbus and from there I can finally manage my triac output directly.
So for the moment, my idea to manage the PWM on the nano in the control basic is in standby.
So the only problem is still the AQ that can be seen by the Nano program
As I could see It in the past with modbus poll, I am sure that nano should make its routing job
The only problem is to get it back on modbus RTU.
I hope that @Temco_Spring can help me tomorrow with this task…
Hi Pierre ,
Please follow my steps as follows to temporarily change the AQ communication protocol from BACnet MSTP to Modbus .
1.First do a direct connection from your PC to the AQ over RS485, just the AQ sensor and your PC connecting for now.
Now, do the same for the T3-PT12, set it to Modbus 115200 as well. Now you can connect both devices to the T3_Nano RS485 main port, they will work at the same communiation protocol (Modbus)and baud rate of 115200. The T3-Pt12 will show up as expansion IO.
You can now connect your Metz triac controller to the T3-Nano subnet over Bacnet.
There is an issue we were able to see for the AQ when communicating under Bacnet, we’ll sort that out and push new firmware shortly.
Thanks for the procedure…
I will this this evening.
I hope that T3000 can see AQ again…
Could you check on your side that AQ signal can be read from a control basic program running in the Nano.
Is there any procedure to save a complete T3000 database setup to retrieve it later when something wrong occurs?
[Moderator] Yes of course, from T3000 navigate to the device you want to back up and then hit File - > Save as, the resulting *.prog file has all your settings and prgramming.
Some times there is a discrepancy between T3000 database and the nano… for example yesterday I saw PRG1 ON with the byte length of the program in the program list but when I clicked on program button, I took a abnormal long time before programming windows appeared and the program was empty…
[Moderator] Haven’t seen this before, could be that the program is getting long or somehow corrupted, save to a text file and we can have a look. You can save just the programming in a text file by from file-> Save as → *.txt from inside the editor.
So how to just save a complete project including IO definition, variable definition, comm configuration, …program definition and content, schedule, controllers and load the whole package later in the nano when I want?
Hello Spring
I could finally put AQ back on the network but problems are not solved.
Nano is not able to read AQ registers.
Or my syntax is wrong
Please check my detailed report sent by mail
I also tested AQ communication trough the routing of the Nano with my RPI using modbus on Codesys.
Reading registers 136 and 137 is working well using modbus function 3
Writing registers 168 & 169 is only working using modbus function 6 ( single register write)
Multiple register writing (16) or read/ write (23) is not working.
Where can I find the list of modbus function supported by Temco modbus slaves especially ?
[Moderator] Search for ‘Network Programming’ on this forum, there are some examples there. The AQ only supports register level commands.
My idea with AQ module was capability to preset setpoint remotely using schedule or HMI interface on my iPad using codesys HMI or later Openhab dashboard but having also capability of local display and temporary change from AQ keypad.
So I need to be able to write SP to AQ but read the modified SP when adjusting on keypad, thank you to confirm it is possible .
[Moderator] Not sure if that is a feature of the AQ but we can add it, there’s the ‘RTS-Node’ which is more like what you describe.
Not sure that switching AQ to bacnet will help for this, but it should be ok if nano control basic program could then manage the SP from AQ.
Hello Spring,
I had this SP feature at the first time I connected AQ on the network.
I was able to adjust Temperature SP, humidity SP and CO2 SP from the keypad.
That was working properly until I tried to change the baudrate and protocol to get the ability to read the values from Nano in control basic.
At that time, the Temp SP was forced to 0 and was not allowed to increase nor from keypad nor from T3000 when connection was sometimes ok. Humidity SP was always allowed to change from keypad … I changed it yesterday after reconnecting using your procedure to check the communication.
After the factory setting reset, this tuning setpoint capability disappeared… I don’t know how to reactivate it. That seems to be just a software problem…perhaps some parameter to change from the modbus poll tool.
I understand my report was quite long but I tried to give details so that you can understand where is my problem and avoid further problem to other user by improving the software and the user manual.
My priority is now to check the capability of read/ write from nano to AQ and Triac output otherwise, nano will be used only as a routing device…
We’re really backed up with a couple urgent projects but will turn our attention to the keypad issue shortly. It only affects the AQ in bacnet mode as far as we know and we’ll address it soon. In Modbus things seemed OK.
As I reported, the keypad function of AQ was working properly in Modbus at the beginning, was working partially after I tried to switch to Bacnet. Temperature sp was forced to 0, keypad access to Temperature SP was still available but up arrow had no effect.
Pressing right and left arrow was not triggering the config menu
After protocol switched to modbus using USBrs485 , keypad function stayed in same partial function ( only effective for Humidity setpoint change )
After factory setting reset, no access anymore to any setpoint tuning using left/right arrows but simultaneous pressing triggers again the config menu.
So we cannot say that keypad is working now… even in modbus.
Il addition, i could never read or write AQ signal through control basic program.
I just would a roundabout to read/write them from higher level using Nani as a pure routing interface .
Waiting for your feedback to go on with my investigation before to buy a T3-LB controller
