where can i download the DEMO PROGRAM below
T3000DEMOSHOW.prg
The following file is 1Heat1CoolExample
1Heat1Cool3SpeedFanRev1.prog (65.6 KB)
You can use T3000 software to create a virtual device and import the file to the virtual device. After importing the file, you can view, edit, modify, and save it.
- You can refer to the following links for more programming commands and methods
Programming for Bacnet and Modbus Subnet devices
where can i find all list (16 program)
thans you
We’re having trouble to find that particular demo program, its from a very early demo we did with mainly graphics and not so much sequence of operations to it. If there’s any application you need help with just post to a new topic with your IO list and rough sequence. I can make a demo program for your exact application.
2 posts were split to a new topic: Single stage cooling example
