Could you please add the parameter to be displayed at the top of the LCD to the information saved and loaded as part of a .proj file.
… need a little help here. Show us what you mean please.
This screen capture is from a T3-OEM but the same problem exists with a TSTAT10. When loading from a factory configuration the parameter displayed does not track with the project. It remains the default until changed manually.
I am interested in terms of the TStat10 as well. Are you referring to the temperature that is displayed on the TStat10 or something in the top header?
Default for the TStat10 is the temperature. You can change it to any input, variable etc using T3000.
