I have problems running T3000 soft,with windows 10 64 bits.
Any fix for that problem?
Thanks
I have been running it on Win10 x64 with no problem. Intel processor or AMD? The only problem I have is the “Do you want to allow this app from an unknown publisher to make changes to your device?” message every time I pull it up. I have already discussed that error with Maurice and they intend to get the software registered with Microsoft so that doesn’t pop up.
Thanks for reminding me, I signed up but didn’t finish through with that task.
I too have problem running T3000 on my machine
Win10 64bit with AMD processor.
T3000 disappears only way to recover is to reinstall and check for updates.
I have deleted all T3000 software and redownloaded from scratch from the Temco website and reinstalled. At this point over 5 times
Problem constantly reappears.
T3000 seems to work ok on win10 64 with Intel processor.
I think what you will find is that the program is being quarantined by your virus program. I had to uninstall McAfee and the problem went away. Go look at the quarantined files and you will likely see the cause.
Bret
Thanks I’ll take a look
John
778 865 5752
John,
Did you have any luck with this issue? Just curious.
Thanks,
Bret
Thanks for asking.
I found 3 modules in quarantined
Re loaded and installed software.
System is more stable but the editor still does not work.
Having a lot of problems getting my TSTAT8 working as well.
Maurice and crew are very helpful.
John
I’m glad some of the issues are resolved. I haven’t had trouble with the editor myself but the Tstat-8 can be a challenge sometimes but mostly regarding updating them.
Maurice and the gang are very helpful.
Bret
Yes they are. I am pleased to work with them
I got the TSTAT8 working using the USB to RS485 cable. I was able to upload the firmware and save the various tables. The wifi now is the challenge. Think I will start from scratch.
WRT the editor is it possible that it doesn’t recognize the keyboard codes. I thought that a keyboard CNTL-(x) would have worked since the cursor control keys are working.
Adds to my learning experience.
Thanks for your help
John
778 865 5752
There may be a few keyboard shortcuts that are not working, I will review the email chain and get them sorted out.
Maurice Duteau
