Hi
I barly install a hum-c sensor and i used the 4-20 output signal and i set farinhaits. Does the output readings soppust to be the same as the display.
Beside there’s another config. And says internal or external. I already make the min and max scale what the data sheet says -22 158f
Well in this picture was C but i was making the test
I try the bacnet integration and works awsome but i disconnected cause i still need the output signal we wanted like that.
