I notice that the outputs have a low limit and high limit setting. For what purpose do these settings have for analog outputs? Originally I was thinking that it limited the output in either direction for a 0-100% range but testing has proven that not to be the case.
It was aimed mainly at damper motors, a range of 0-100% would show 0-100% while the analog signal varied from 2-10V rather than the usual 0-10V. Its not used all that much since we also have a dedicated 2-10V (0-100%) range. I will have the team check that its still working and report back here in a couple of days.
