So you can easily set or change your input types via a node-red dashboard either locally or via the internet anywhere, anytime.
Also of note is that this node-red BACnet module automatically retrieves all the points of all the BACnet devices on your network.
For more info see microgro.co
There is a link to a live node-red cloud demo and if you navigate to Devices you can have a play setting the input types.
(Don’t worry, there is nothing attached and ui3 and 5 are disconnected in the flow.)
enjoy
maurice
October 12, 2024, 12:15am
2
Thanks for this Microgro, keep it going. More examples.
Thanks for the comment.
Not sure what you mean or want by ‘more examples’?
The iBox BACnet read and write nodes can r/w to any Temco device BN points such as ip address etc. and is very simple to setup in NR …
HTH
m
Well something like the other node red project on the forum for a Modbus node red example, it showed an example of several thermostats with a dashboard for a typical home automation project.
Updated GUI with SteelSeries-Canvas Gauges;
[image]
download new flow at end of post.
Here is a Node Red GUI that I have been working on;
[nr_main_ui]
[image]
[image]
The configuration ‘Tab’ allows configuration of the Number and Name of each room/sensor, and the Register Value for each. I am currently using this with a Temco Controls Tstat8 , but the same flow could be used with other controllers by configuring the registers for the device. This Node-RED ‘flow’ is currently configur…
There are plenty of examples on the microgro.co website via the Live Demo link such as the following …
and it has usb Modbus serial … from the iBox to the various sensors … no DDC controller needed …
The above AHU graphic uses the following node …
https://flows.nodered.org/node/node-red-contrib-ui-svg
and is capable of graphical animation etc.
This is a copy of an actual iBox microgro.cloud working system in the UK used in a vertical farm for growing microgreens.
The Kasa WiFi mains power strip output node shown is not connected to anything in this live demo but is used to control the LED lighting on the farm.
If anybody is interested in becoming a reseller for the iBox and microgro.cloud system, contact us via the website.
cheers
mh
