I was hoping to get some clarity on the following specific items (on a Tstat7):
I need 4 basic items when I poll the device to report accurate status of what the unit is doing.
1) HVAC Mode (tstat setting):
I see register #101 (COOL_HEAT_MODE, heating or cooling mode. 0=none, 1=cooling, 2=heating)
Is this the correct register?
How can I tell if the thermostat is in Auto mode?
I also see regs 106/107 referencing modes but not sure what they do.
2) HVAC State (what is the tstat doing):
I see register #102 (MODE_OPERATION, heating or cooling state: 0-7 = coasting, cooling 1,2,3, heating 1,2,3)
When I poll 101 & 102 and get back : 0 & 0 I assume that means the unit is idle - right?
How can I tell if the thermostat HVAC mode is set to “Off” - can it even be set to off?
3) FAN Mode (fan setting):
I see register #105 (number of fan speeds or system modes,… Single speed = 1 up to three speed fan = 3)
I see it is always “1” which is indicating speed but not mode
4) FAN State (what is the fan doing):
Not sure what register to find this info… can you advise on this?
I have tried manipulating the device with the “Mode” button but it is not entirely clear what is happening to the above registers when I cycle through them.
Options I see on the Tstat7 device:
FANMODE: [ -AUTO- | MAN OFF ]
HEATCOOL: [ AUTO H/C | MAN COOL | MAN HEAT ] (register #101)
Thank you!
