Hello everyone, I hope you are very well, I am writing to you from Chile, the first time we work with temco controllers specifically
T3-OEM-W, Our installation consists of 4 air handlers with supply and return fans, with 0-10Vdc motorized valves for hot and cold coils. temperature sensors for return impulsion and outside air, in addition to the status of fans with differential air pressure switches and, in addition, an AFS-200 air flow meter for ducts. The application is more similar to the functions of a Tstat8 Thermostat.
Is it possible to load configuration of a Tstat8 in a T3-OEM-W?,
I need help
Thank you very much in advance
