I need 4 analog outputs from T3-LB-ASIX, two are AO by default and two are universal outputs. Universal outputs work fine as relay outputs, but then you set it to 0-10 signal it do not output any signal at all.
I use AC ~ 27v to power up controller.
Its in fact the T3-TB which has the universal outputs and the default setting is indeed relay mode so you’ll need to move a couple jumpers. First take the cover off and then two more screws to remove the topmost board. On the lower PCB you’ll see the jumpers, the large silk screen text shows where to move them for analog mode, to the right for analog mode.
