As you know I have been working to put together something for a customer to control humidity in their location.
The tstat8 reads humidity, but doesn’t control it.
I got a Tstat10, but I am having problems writing programs to it. I keep getting an error.
I have a T3-TB, and thought “Ah! I will use the T3-TB to do the control, and connect the Tstat8 to read customer setpoints and space temp and RH, and do most of my programming in the T3-TB, which can be mounted in the AHU for best control!”
But…
I cannot seem to get the T3-TB to see the Tstat 8. I have updated all firmware, tried setting the T3 485 ports to Modbus Master and Slave, have tried on both ports, for the hell of it tried BacNET.
But the T3 just does not see the Tstat 8.
What am I setting up wrong on the communications?
I can, however, connect to the Tstat8 via USB to 485 converter. Just cannot connect through the T3.
