Is there any public tracking of issues raised in the software? I would like to understand if some reported issues are in progress or never made it further than the forum Q&A.
Yes, the developers maintain a TODO list. If you would like to make sure your issues get promoted to that list you could raise an issue on the github repo. This would be appreciated in fact and I will make sure that they are taken care of by our team:
Use this repo for firmware issues:
https://github.com/temcocontrols/T3-programmable-controller-on-ESP32
Use this repo for T3000 front end issues or if you are not sure.
https://github.com/temcocontrols/T3000_Building_Automation_System
I had raised several issues in github 3 months ago but have not heard back on them. Would it be possible to get an update on any of them?
Thanks,
Jason
First question was where is the code for teh STM version of our controller, its ritht there in our list of repositories:
The second question was about a compile error, Lijun has updated the documentation a few times since then based on feedback from others. He will check your comments and try to help.
The issues I had raised were these ones:
Thanks,
Jason
Lots of good feedback there Jason, thanks for your effort with all of that. Our team will be working on the list… its a long one but many good ideas. Appreciated.
I see from your personal repos you have been doing some good work as well. You should check out the work going on under the T3000 repo with the javascript webviewer graphics system, it seems a good fit for your projects.
