WireGuard is a new VPN protocol that has recently been gaining a lot of popularity.
There are a couple of advantages to using the WireGuard VPN on your Raspberry Pi over OpenVPN.
WireGuard is much faster at making connections than OpenVPN, it can complete a connection within a tenth of a second.
The codebase for WireGuard is also drastically smaller then OpenVPN’s. This allows the software to be more secure thanks to the smaller attack surface and bugs being able to be dealt with easier.
For comparison sake, WireGuard only uses 4,000 lines of code compared to the 70,000+ lines of code that OpenVPN uses.
The only notable disadvantage of WireGuard is that it does store the connecting user’s IP addresses. It does this to improve the connection speed.
The reason for share this article is that we can use it with T3000 to acess the remote devices. you just needs a 1 Pi with wireguard running on your remote site and you can acess all of them from other network by adding them thorugh add remote devices popup . and for client end it can be a Pi or Windows PC.
Actually its create a secure VPN tunnel between the client and server end Communication.
In this Artical we will configure the wireguard server on 2 Raspberry PI with Server and client End.
Requirements:
- RaspberryPi3 with Rasbian OS
- 8GB microSD Card
- Pi-Power Source
- Ethernet Cable
- Putty Software for PC
- Public IP on Server Pi.
Step-1
- Connect Your Raspberry Pi with your PC through Ethernet Cable (RJ485)
- Login to your Raspberry Pi using your User Name and Password using Putty software
- Connect your PC to Internet
Step-2
Update and upgrade your Raspberry Pi Using this Commands
#sudo apt update
#sudo apt full-upgrade
Step-3
Installing Required Package
#Curl -L https://install.pivpn.io | bash
- Wait for the process to install the Packages. When it’s done another screen will ask for permission to install to install Open VPN or Wire Guard on Pi click Ok.
- After click OK Another window will POP up click on NO Button
- After that you need to select PI by pressing Backspace and click on OK Button.
- It will ask for VPN Type. Select WireGuard VPN.
- After that it will ask you about port number Allow by default Port Number and Press OK.
- Another Window will Come Press Yes.
- After that select PIVPN and Press Ok.
In two different ways you want to access your Wire Guard VPN. Select use this public IP Press ok.
Now it will ask you to enable unattended Upgrade click YES.
- Press Ok installation is now Completed it will ask you for Reboot Press OK.
After installation process wireGuard server will be in running mode and will generate the wireGuard configuration automatically you can edit them by using the following commands.
A new adapter created with wg0
#ifconfig
will show the available interfaces on your Pi.
#sudo Su
#nono etc/wireguard/wg0.conf
Step-5
PostUp PostDown
Copy the following command below DNS in server PI wg0.conf
PostUp = iptables -A FORWARD -i wg0 -j ACCEPT; iptables -A FORWARD -o wg0 -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE; iptables -A FORWARD -i eth0 -j ACCEPT;
PostDown = iptables -D FORWARD -i wg0 -j ACCEPT; iptables -D FORWARD -o wg0 -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE; iptables -D FORWARD -i eth0 -j ACCEPT;
Above image it screenshot is the configuration of the wireguard server you can generate the clients configuration file by following the below steps.
Creating Profile for client
you just have to input the names of client file it will auto generate the configuration for that in configs folder.
#sudo pivpn add
Generate Conf File for Client
#cd configs
#ls
#nano Client.conf
You can download that file or copy the configurations.
Download Wire Guard Desktop app
WireGuard for Windows Downloads
Install it into Client PC Run the App.
Click on Add Tunnel add load the Client.conf file and Press activate Button.
How to make PI As a Client on VPN Wire Guard
Follow the Same above Step for Client PI VPN Wire Guard As for PI Server
Run this command on Client PI
#nano/etc/wireguard/wg0.conf
Run the above commond also on Server PI
You have to copy the Client configuration text override on wg0.config and save it.
And restart the WireGuard service on Client PI
#systemctl restart wg-quick@wg0
You can Ping the sever to test weather wireguard is working by connecting you system on other netwok and activating the wirguard
