my T3-TB usually works normally.
I’ve added a simple water meter which is connected (2 wires) to an input (set to Pulse Count Slow 1Hz). No programming for the moment. This system worked as expected for about a day, accumulating increments in this variable (1 count = 1 gallon).
The next day, I noticed that my meter was at about a few dozen gallons, whereas the day before, it was at about 500 gallons. A control graph showed me that the counter went to zero at around 3 a.m. The next day, it was at a few dozen gallons.
No power failure at that time (I have another T3-TB that didn’t reset).
More surprisingly, only this variable went to zero, while other variables of the same type (used as counters) retained their values.
Do you have any idea why this happened and why just one variable reset to 0?
A (perhaps stupid) idea: would this error be possible if the counter stopped just at the moment of “contact activation” measured by the T3 unit?
Update for today
Some entries have been changed spontaneously today for unknown reasons. See image below.
5 variables lose their range and become undefined.
And, of course, the program that manages these variables no longer works as intended.
Is my unit dying?
In the meantime, again, when I reset my unit, this new variable (Pulse Count Slow) loses its value (resets to 0), while the others, previously created, keep their value.
is it possible to force a value into a counter? When I set a value for this variable, it spontaneously resets to the value measured before the change.
Was it 0? It resets to 0
Was it 5? It resets to 5
Update 2
I solved the problem of variables losing their range.
Another PLC extracts (modbus) values from this T3-TB (statistics and monitoring). For some unknown reason, some parameters of this PLC are interfering with the variable itself (its range).
I removed the monitoring from my plc and the variables kept their range, which solves my first problem.
There remains the problem of the variable resetting to 0 on T3 reset, and the possibility of forcing a value for this kind of variable.
Update 3 (partial solution)
I created another variable (Pulse Count Slow) which takes the value of the first variable (which spontaneously sets to 0) according to :
40 IF WATGNOW <> 0 THEN WATGDAY = WATGDAY + WATGNOW , WATGTOT = WATGTOT + WATGNOW , WATGNOW = 0
50 WATLDAY = INT ( WATGDAY * 4.546 )
60 IF TIME = 00:01:00 THEN WATGDAY = 0
where WATGNOW is my problematic variable and WATGDAY is the variable that memorizes the value of WATGNOW (but does not reset when the T3 reboots).
So the only question left is: why does one Pulse Count Slow variable reset and not another?
