Q1:
I find a problem as below
After success set MODBUS_VAR_VALUE from HMI & double check with modbus poll
If in a few time to power off the T3-LB
I find T3-LB 'flash seem not keep up the data (like temp/humi setpoint)
please guide me through the process
Q2 :
Register_Address 62 write flash time after changed setting. Unit is minute
the defa val = 5 what this is meaning ??
& Q2 is relational with my problem Q1 ?
Question1: Losing data
I think you are saying you did some programming in the T3-LB and after cycling power the changes were gone. How it works is that the T3-LB will automatically store your changes to flash periodically in the background every few minutes. It will also write to the flash whenever you save or load a program so if you are working and cycling power frequently you will want to save the program or manually save to flash before power goes down.
Question2: Not clear but it sounds like you are asking what is register #62 on the T3-LB product. I show its the ID of the subnet device you would like to talk to when doing some subnet operations. The modbus register list is here for reference. https://temcocontrols.com/ftp/software/03ModbusBacnetRegistersList.xls
And here’s the view from the Modbus register viewer tool which will be helpful while integrating:
