From what i understood in description it is possible to use PWM transducer as IO module.
AI then i use analog input as 10K thermistor all is fine,but then i switch to 1-10V reading is always 10V. It works fine for converting relay output to analog output,but can it work as simple 0-10v analog input? Also can transducer functionality be disabled and connection between inputs and outputs broken?
AO then i turn on AO it is turning off in one minute, as i understand this is done because this device primary PWM functionality, can it be disabled? I tried to turn on output from T3000 software, may be if i whould use modbus or bacnet registers it will behave differently, but my first attempts to write Modbus registers wasn’t successful. .
