Minor issue with the keyboard interaction with a multistate variable type (101). I originally set Var2 type to 101 with 3 states then modified it later to have 7. When using the up or down arrows keypad still limits access to only 3 states. T3000 software appears to work properly.
We shall investigate and fix. Thanks for the heads up.
I fixed in the latest firmware rev65.1, you can update it.
Just an FYI. When I updated the firmware it appears the input, output, and variable tables may have had the high and low order bytes swapped. The PID loops also have issues and the programs still have sizes but no contents.
You may have to update T3000 itself and reload the prog file to the controller. Send a screen shot and the prog file if you are still having troubles.
