Since I have connected up to 4 T3-22AI on the Main RS485 interface of T3-BB, I tried to use the following command to read inputs above the maximum 64 inputs but it doesn’t work.
10 VAR92 = 14.100.MB_REG101
Where 14 is the panel number, 100 the T3-22AI modbus Id and 101 the input 1 of the expansion module.
However with Modbus viewer tool the values of inputs are correctly displayed.
I believe we have increased this to 128 with the latest firmware. Update the T3-BB and may as well update the 22i while you are at it.
When the expansion units are set up as expansion IO there is no need for this intermediate step to assign the input to a var, you can use inputs directly in your programs like so:
When the inputs are recognized they should show up here, not as virtual but as regular ‘Analog’ inputs, we should change that to ‘UI’ since it could be binary as well depending on the range setting.
Please update rev65.3, previous firmware versions did not support 1.2.MB_REG for accessing points that had been identified as extended IO, and we fixed this bug in rev65.3.
In general, access to extended IO is similar to access to internal IO, but if the number of extended IO is too large (input more than 64), you may need to use a method such as 1.2.MB_REG.
However I urge you to get familiar with the intrinsic method, IN78, IN99 and so on. It is far easier than looking up registers and massaging data formats. If you are not clear what I mean feel free to ask.
