Hi Again,
I am working on integrating a small network of Reliable SSC stats on ms/tp, but I am having some troubles. They just don’t seem to show up at all. Has anyone given this a try and was it successful? The SSC’s are a BTL listed device so this should work, but I am not getting far.
Also, perhaps related/not related, has anyone had weirdness with trying to change the settings on the RS485 ports? From T3000 in the settings-communication tab, I can select the MSTP Master, but I don’t see normal light activity for an mstp network and I have no luck with scanning for devices other than my LB via ethernet.
I had a look in modbus register list for my LB and the listing doesn’t show a baud rate for 76,800. I had thought this was added at some point, but it doesn’t show. Also it is really confusing which com port is which. There is a listing for Com0, 1 & 2.
Ideas?
