Yes, this is the log:
logs.txt (572.4 KB)
I install this SDK: https://dl.espressif.cn/dl/idf-installer/espressif-ide-setup-2.8.1-with-esp-idf-4.4.4.exe and copy 3 folders to component folder and replace the original driver folder. It is esp-idf-v4.4.4 You can try to re produce by fresh install with above SDK.
