I am trying to find more information on the TBL function and the setup of tables themselves. The TBL function takes an expression and a table number but I am not sure of all the ways in which tables might be defined. The example (T3000 Custom Tables for Transducers with Negative Values - #2 by maurice) shows the tables only in relation to Range setting for inputs and outputs.
Is their only intent as a static value mapping tool? In other words, there is no intent to allow dynamic lookup tables making use of the TBL function for retrieval?
