Found out how to change the text/value for the 3 data row, but was wondering if it’s possible to make them read only.
Also find out how to hide the icon/scrolling text, but is it possible to change the text for the scrolling data? And is it possible to customize the ICON?
Also is it possible to have more than 3 row of data displaying ?
There’s not a lot of cusomizing you can do regarding what is showing on the display. These are mainly aimed at commercial buildings so we havent developed a lot of features. If you have something you’d like to see there we can work on it.
VAR2 and 3 can be made read only using a program. The values you want to be write protected can be in say, VAR4 and 5. The program just goes VAR2 = VAR4 and VAR3 = VAR5. The user cannot adjust VAR4 and 5 but can see VAR2 and 3 on the display. Adjusting with the keypad will have no effect due to the program overwriting the changes.
Rotating Text: You’re right, we need some features for what shows up in the rotating display. We’ll check into more lines as well.
That part I get. The part I don’t get is the variable part of the row. For example, If I make the label “Fan”, then how do I make it so that it has value of “Off”, “On”, or “Auto”?
Here’s an example of how to configure the Tstat10 and its display:
The trick to showing OFF-ON-AUTO and other text type values is to use one of the MSV’s, multi state variables. They show up as one of the special ranges for the vars.
