We are replacing a MicroZone 2 with a T3-LB to control contactors for lighting. We have a Hand-Off-Auto selector switch tied into the controller.
We can program the “Hand” side to turn all the lights on but having trouble with the “Auto” side. The desire is to use 2 of the WR Schedules when in auto (1 for 2 different sections of the building) but the T3000 help file says : cannot start weekly routines in basic. How is this to be done with a selector switch turned to auto?
Also, could you give an example of a weekly routine turning on & off certain outputs of the T3-LB while in auto. Daytime (all assigned outputs on); Nighttime (all assigned outputs off).
Then in PROGRAM, you can associate the schedule and the output port in the following way, such as the following statement, SCH1 is the first line in the interface, OUT1 is the first OUTPUT port, so that you can switch the OUTPUT according to the task of the time period in SHC1.
Thank you for the detailed procedure above, very helpful!
In this statement, (copied from the instructions just before “tab 13”) how do you turn on and off the schedule by way of an input from a selector switch? In other words, how do you make the schedule false by way of the selector switch turned to “Hand” or “Off”?
