Hello Everyone,
I’m trying to get the input (UI1) to work with the PT 1K Duct Temperature Sensor. One wire is going to ground the other to UI1 on the TSTAT10. However what values do I have to select on the INPUT side (IN1) for Range and Signal Type to get a proper reading?
The option for PT1K is not selectable, however you can manually enter 39 for the Unit Number and it will select it, I have changed the Signal Type to PT1K but I get a reading of -200oC, I switched the sensor with another one to see if there was a short, but I get the same thing.
Any help would be appreciated. Thanks.
