- Program HOL and SCH lable can use “Insert” key to show or edit the value .
- Auto update the file “Update.exe” .
Fix the bugs ,download the old version of T3000 software.
- Fix the feature “load” “save” prg file . when the program file is lager than 1600 bytes ,it cause decode error .
- Fix the Old T3 panel which program size is only 10000Bytes , don’t allowed user coding more than 10000BYTES.
Fandu,
Thanks for your continued improvement of the T3000 software. Can you provide more info about change #1 in this post? How does the “Insert” window pop up? What’s an example of how it would be used?
T
Select the keyword or move the cursor to the label, then click the Hotkey “Insert” , T3000 will find out which label it is , If it is a input label ,It will popup a debug window .Also Output ,variable , PID ,SCH,HOL.
For more details ,you can reference the user mannual.
https://temcocontrols.com/ftp/file/T3000/T3000SoftwareManual.pdf
