T3000 BB hardware question
Just start working with a T3000 and have 2 basic questions
  1. Is it normal that there is no USB port ?
  2. Manual state that you can use a 12V or 24V AC/DC power supply, but the physical board only mention 24V, which one is right
  3. The manual output switch have 3 options H O A, I suppose A is automatic, but what is H O meaning?
Thank you
1- no USB port is normal.
2 - 24Vac is most common but the system accepts the 12 to 24V ranges in Vac/Vdc.
3 - HOA is industry standard for: Hand - Off - Auto. Hand activates the output, off deactivates the output and Auto allows the program and user to control the output.
