How it’s possible to read data from bit mask?
“The following are examples of reading a subnet device with Modbus ID=10 connected to a master controller on the Ethernet network with ‘Panel ID’ = 97
10 VAR10 = 97.10.MB_REG7
20 VAR9 = 97.10.MB_REG & 1
30 VAR9 = 97.10.MB_REG | 1
Use & (bitwise and) and | (bitwise or) to manage bit level read & write.”
For example, I have to read data from register 772 and I need bits from 9 to 12. Is it possible?
VAR1 = 1.10MB_REG772
VAR2 = 1.10MB_REG & 9
VAR2 = 1.10MB_REG & 10
VAR2 = 1.10MB_REG & 11
VAR2 = 1.10MB_REG & 12
Something like this?
I didn’t succeed with it and can’t find any information.
Thanx
              Chelsea will report back on this shortly.
              T3000 only support decimal, so we have to transfer to decimal number
BIT9 →  1 0000 0000   =>  256
VAR1 = 1.10.MB_REV772 & 256
BIT10 → 10 0000 0000
VAR2 = 1.10.MB_REG772 & 512
BIT11 → 100 0000 0000
VAR3 = 1.10.MB_REG772 & 1024
BIT12 → 1000 0000 0000
VAR4 = 1.10.MB_REG772 & 2048
              Hi @chelsea
Thanx. But how can I read the data from 9th to 12 bits together?
VAR5 = VAR1+VAR2+VAR3+VAR4?
One more question.
Does T3000 supports 32 bits registers?
Thanx a lot
              T3000 doesn’t support 32 bit register, you can combine 4 bytes to 1 long.
              Thanx @chelsea
How to combine it? Which syntax to use?
              Hi, @chelsea
16777215 - bit 24, minus one
65535 - bit 17, minus one
For what we use this bits / this numbers?
Why you didn’t multiple the last VAR?
I got the value 4127 but supposed to be 0-15.
Here’s an example, take a number of bits from BIT9 to BIT16 and then combine them to one byte.
              @chelsea got it. Thanx!
And VAR25 = 1.10.MB_REG2049, right?
              I just did a simple demo. You can use 1.10.MB_REG2049 to replace VAR25,
