Need to change the MSTP Network
I been using the t3-nano and I need to change the network ID to other than 1, for two reasons
  1. I need to implement multiple of these on a site and it will clash with the network ID.
  2. The number 1 is common and has to be something other than 1.
See how it shows up on the tridium when scaned.
I noticed that your firmware version is quite old. I suggest you update the firmware and also update the T3000 software. This should allow you to change the MSTP network.
T3000 update: T3000->help->Update T3000
Firmware update: Select the device to be updated in the list on the left, T3000->Check for Updates.
A post was split to a new topic: Subnet Communications Troubleshooting
