Do I need to jumper all 16 positions?
Also are there traces that need to be cut?
Thanks
Yes you need to jumper all the pins and cut the associated traces for all eight relays. We can do it for you at the factory if you are considering buying them regularly. If you need more info on the procedure I can get that into the documentation.
Maurice Duteau
