reviving this post, I received a 10k floater and a liquid level sensor and I tried to hook them.to a T3.
The liquid level sensor is a 0.10V unit and the result is enough sensitive: I obtained nice curves of the voltage variations.
However, despite the fact that the floater is a 10k resistive unit (I tested with an ohmmeter and the results is accurate: from 0 to 10k ohm by 1k steps), I tested a T3 without positive results: selected as a 10K temp sensor (…) or created a custom table with no real results. I can’t retrieve the resistance values.
Some advice is welcome.
I don’t need to convert values, I’ll be glad if I can obtain values (ohms), my plc will do the maths.
Thank you
