For IP points we tested and its working well but for RS485/mstp points I can see there is a problem. We need to set up a test environment here, no products on hand have objects up in the 400+ range. I have done a small test update with firmware rev51.9 which you could try downloading using the usual firmware update system. I will check more on Monday if there are still issues.
