Hello! Could you solve the issue of failures in Start8 when you wanted deadzone values close to zero? Thank you.
You can set the deadband to 0.1 DegF/C in the latest firmware. Update your device and give it a try. Letting the user set the deadband to zero will cause short cycling so I have been hoping to avoid going smaller than 0.1.
Thank you! 0.1 deg is perfect…!!
