hi maurice
i have T3000 and T10 stat i was up dating it other evening an when it was all but thur in it update it would not open up the software program it wou i try ever thing i no to do i finally reinstalled the software before it would open to were i could logon to the software at all but the software was out of date so i try to update it to the latest then when it was about thur it done the same thing again.it would not open or login in DWAYNE
Its difficult to say what is going on from your description but in general, if you are having trouble updating T3000 you can always download the fairly recent version here:
Once you have that downloaded, unzipped and installed you can run it and head to T3000 → help → check for updates to get the latest & greatest T3000.exe.
Once you have that running you connect and try scanning for devices. If you cannot connect then you can search this forum for ‘can’t connect’ and you’ll get many tips. In general its:
Connect over Ethernet if possible
Shut down other software that might be using the bacnet or modbus ports, including niagara whcih I have seen running as a service.
Temporarily disable virtual adapters, wifi, vpns and such. Use just the one and only wired ethernet adapter for scans.
If you have tried upating and perhaps only got part way thgouh the update, cycle power and try updating with the T3000 → update a single device, its called ISPTool and its a little simpler than the usual T3000 iunterface. Cycle power to the device and try the update in the first few seconds after power is coming on. The LED or backlight if it has one will be blinking with two blips, repeating every second or so. This is the time to do the firmware update. Search this forum for keyword ‘unbrick’ for more details.
i did reinstall the software again and each time it would not open anymore. Then when i open it, it was ok until i updated it then it would give me same thing and would not open. The application was not able to start correctly (0xc0000005) can you please help thanks
Hard to say from teh description what might be going on. Send on a few screen shots or reach out to us by email and we can coordinate a session over anydesk or teams.
HI MAURICE
I WAS STILL HAVING PROBLEMS WITH SOFTWARE IT NEVER WOULD LET ME UPDATE SO I WOULD HAVE TO REINSTALL SOFTWARE IF IT TRY TO UPDATE THEN I HAVE A SOLAR SYSTEM AND I WAS HAVING TO CHANGE MY BMS CONTROLLER TO A BETTER BMS CONTROLLER THAT WOULD HANDLER MORE BATTERY BACKUP IN MY SYSTEM THEN I WAS TRYING TO DOWNLOAD THE SOFTWARE FOR IT BUT IT WAS DOING THE SAME AS MY T3000 SOFTWARE BUT IT WOULD NOT INSTALL IT AT ALL THEN I CALL SUPPORT ON THERE SOFTWARE WE TRY A FEW UPDATES BUT NO GOOD THEN SUGGESTED A UPDATE ON MY WINDOWS 7 IS WHAT I HAVE BUT THEY SAID UP TO WINDOWS 10 AND I DONE THIS THEN I REINSTALLED THE T3000 SOFTWARE AND AND IT INSTALLED IT OK AND IT UPDATED TO THE LA I NEED TO NO HOW TO GET MY GRAPHS TO WORK WERE I CAN BUILD IN THE GRAPHS I JUST WANTED TO LET YOU NO WHAT HAPPEN WITH IT THANKS MUCH DH
2024-11-17T05:00:00Z
I don’t know if I understand it right, it sounds like you have installed T3000 software in Windows 10 system, want to make graphic work, so late I suggest you read this post:T3000 Webview graphic quick start
