Good morning, i need the dimensions of these values of the temperature sensor
Temperature Transducer With Bacnet And Modbus Rs485
| 34 |
1 |
MODBUS_TEMPERATURE |
03 Read Holding Registers (4x) |
16 Bit Signed Integer/10 |
| 35 |
1 |
MODBUS_HUMIDITY |
| 41 |
1 |
MODBUS_DEWPOINT |
| 42 |
1 |
MODBUS_ENTHALPY |
| 44 |
1 |
MODBUS_ABSOLUTE_HUMI |
The data for Modbus registers and Bacnet objects is in the product documentation which you can download from the website product pages. If we’re missing something you can let us know.
That said, the there are some tools available in our T3000 which will make your job of integrating go much faster. You can download T3000 from the product pages and once you are connected, scan for devices and navigate to the Bacnet tool at Tab1 to see all the Bacnet objects. If you’re working with Modbus then you can use the T3000 → Tools → Register viewer at Tab2, there you can see all the registers, their names and the current value.
And another good resource is the database of devices and Modbus registers which you can find at Tab3, its in microsoft access format.
