Hi All,
I faced the problem during set up new temperature/humidity sensor.
So the sensor type is Vector,I connected to it via T3000 and gave the value 0-10 V the button #46 but the reading value is strange.
I don’t understand what is the problem.
Can you help me
This is best handled by the custom analog input ranges. Here’s a link, follow the instructions there and report back here if there are problems.
Thank you for response.
I have another question.It seems that my controller converts resistance to temperature and in the table you sent, I don’t see how resistance can be converted to temperature. There is a uniform option to choose between temperature sensors.
I connected simple 10K sensor and I can read the temperature.
I am not fully following the question but the basic idea is there’s several built in ranges for 10k thermistors, type 2 and type3.
If you have a custom sensor with a different resistance curve you’ll have to build a table of resistance / voltages and temperatures which you can do with some simple voltage divider math. I’ll dig out a spreadsheet if that’s where you’re headed.
