There are two delay options in the modbus integration I missed and I need to keep connection open on fail. This seems to be a stable config for my Airlab:
Phew, thanks for sticking with it ‘8098. If there’s anything else we can help with let us know. I believe doing this with the HA bacnet integration would go a lot smoother.
This isn’t about how fast the Airlab replies, it’s about the necessary delay(s) between connect and first read and between the numerous reads themselves.
We had one person working on it and HA recently. There were some problems but we got it working for the main Ethernet port devices. We were working on discovering subnet devices when we left off and havent heard much from that client in a while now. You could write to the HA folks, they were supportive.
No, with the available config settings in HA modbus integration all is well, the only challenge for somebody new to the matter (like me) is that the Airlab is quite silent when using the defaults…
Ok, so the problem is, you should not hammer the Airlab with requests. After TCP connect, HA needs to sleep for ~200ms or it won’t respond at all (delay). And after a single read holding register, HA needs to sleep at least 100ms before sending the next read holding register (message_wait_milliseconds).
If you do that, all is well. If you don’t the Airlab is as dead as a doornail.
Yes, please try to ensure the read interval of more than 50ms, reading too quickly will overload our devices which results in lost packets. Read intervals of more than 100ms can ensure that there is almost no packet loss. In practice the temperatures in the building dont change all that fast and a typical poll interval would be ten seconds and more.
If there are more than one master polling the device you will need to take that into account as well, our devices can support siultaneous connections to several masters but you will begin to see packet loss as the load increases.
Yes, that’s what I discovered. The only addition to that: it’s not only the polling frequency in HA, but also the inter read interval timing that needs some delay, because I have HA configured to read every holding register as a seperate sensor. I know I can get a set in one call, but then the sensor naming in HA is not as clarifying as I want it to be (each holding register has it’s own sensor config now).
No, what I’m saying is that one needs to wait at least 100ms between every read. Which can be configured using message_wait_milliseconds: 100 in HA, so no problems, nothing to solve. Just reiterating what was discovered in the thread. The problem is solved.
