I was implementing a flying sample routine on a tstat10 and I believe I have identified a problem accessing arrays. after trying severalvariations I believe the problem lies with pushing and pulling data from arrays.
Here is the program. I should sample the temperature every 2 seconds and calculate an average. The only code that works does not use arrays.
10 REM REQUIRES ARRAY 2 AND ARRAY 3 TO BE LENGTH ARRAYSIZE
20 ARRAYSIZE = 10
30 IF INTERVAL ( 00:00:02 ) THEN SAMPLEINDX = SAMPLEINDX + 1
40 IF SAMPLEINDX >= ARRAYSIZE THEN SAMPLEINDX = 0
50 REM USING CALCULATED INDEXING
60 IF SAMPLEINDX <> OLDSAMPLEINDX THEN OLDSAMPLEINDX = SAMPLEINDX , AY2[SAMPLEINDX] = IN9
70 REM USING FIXED INDEXING
80 IF+ SAMPLEINDX = 0 THEN AY3[0] = IN9 , VAR70 = IN9
90 IF+ SAMPLEINDX = 1 THEN AY3[1] = IN9 , VAR71 = IN9
100 IF+ SAMPLEINDX = 2 THEN AY3[2] = IN9 , VAR72 = IN9
110 IF+ SAMPLEINDX = 3 THEN AY3[3] = IN9 , VAR73 = IN9
120 IF+ SAMPLEINDX = 4 THEN AY3[4] = IN9 , VAR74 = IN9
130 IF+ SAMPLEINDX = 5 THEN AY3[5] = IN9 , VAR75 = IN9
140 IF+ SAMPLEINDX = 6 THEN AY3[6] = IN9 , VAR76 = IN9
150 IF+ SAMPLEINDX = 7 THEN AY3[7] = IN9 , VAR77 = IN9
160 IF+ SAMPLEINDX = 8 THEN AY3[8] = IN9 , VAR78 = IN9
170 IF+ SAMPLEINDX = 9 THEN AY3[9] = IN9 , VAR79 = IN9
180 REM AVERAGING LOOP
190 TOTAL = 0
200 TOTAL2 = 0
210 FOR X = 0 TO ARRAYSIZE - 1 STEP 1
220 TOTAL = TOTAL + AY2
230 TOTAL2 = TOTAL2 + AY3
240 NEXT X
250 VAR100 = TOTAL / ARRAYSIZE
260 VAR101 = TOTAL2 / ARRAYSIZE
270 VAR102 = ( AY3[0] + AY3[1] + AY3[2] + AY3[3] + AY3[4] + AY3[5] + AY3[6] + AY3[7] + AY3[8] + AY3[9] ) / 10
280 VAR103 = ( VAR70 + VAR71 + VAR72 + VAR73 + VAR74 + VAR75 + VAR76 + VAR77 + VAR78 + VAR79 ) / 10
290 REM DEBUG STUFF
300 VAR90 = AY2[0]
310 VAR91 = AY2[1]
320 VAR92 = AY2[2]
330 VAR93 = AY2[3]
340 VAR94 = AY2[4]
350 VAR95 = AY2[5]
360 VAR96 = AY2[6]
370 VAR97 = AY2[7]
380 VAR98 = AY2[8]
390 VAR99 = AY2[9]
400 VAR80 = AY3[0]
410 VAR81 = AY3[1]
420 VAR82 = AY3[2]
430 VAR83 = AY3[3]
440 VAR84 = AY3[4]
450 VAR85 = AY3[5]
460 VAR86 = AY3[6]
470 VAR87 = AY3[7]
480 VAR88 = AY3[8]
490 VAR89 = AY3[9]
I would expect variables 100, 101, 102 and 103 all to contain the same value.
