Some time ago (months) there was boot loader update. After it controllers often (20%) crashes during update. After that controller restarts go to ISP mode and in few attempts you can push update. Haven’t noticed it before boot loader update.
We’re going to need a bit more than this to go on but in general T3000 will check if the device needs a new bootloader before it performs the usual firmware update. If so it will take care of updating the bootloader followed by an update of the main firmware. Be sure to use the latest T3000 when doing updates that require a bootloader update, the more recent the better your experience will be.
Last time I tried “Loading update to many devices” system crashed dramatically. I spend a lot of time restoring it. Now I do update one by one and situation is manageable, only 1 of 15 controllers failed to update yesterday.
Just wanted to report that I experience small difficulties and I do not recommend using “Loading update to many devices”.
Make sure you have the most recent version of T3000 to test that. We did some work on mass updates about two months ago.
Fandu will check this out.
You can try updating again to resolve this issue.
If some devices still have problems updating firmware over the network, you can also temporarily update firmware over RS485.
