Where can i get the modbus register for Tstat7, based on the list provided in “03ModbusBacnetRegistersList.xls”, the worksheet stated Tstat8… does the register of Tstat8 same as Tstat7?
Yes they are the same. Also you can connect with the T3000 modbus register tool and see all the registers, data format, names and current value.
What you meant is that i need to use the T3000 in order for me to cross check the modbus register in the Tstat7?
You dont need to but it will make your work go a lot faster, yes.
