Tstat10 Basic RTU Program
Just looking to run a basic occupied, unoccupied, single stage gas heat, 2-stage cooling thermostat to control an RTU. No auto change over necessary all modes will be manually switched at wall controller.
I believe I got all the inputs, outputs, PID, and schedule setup correctly. Just looking for a simple straight forward program to run.
Would you mind to send on the prog file, you can save it locally using the T3000 → file → save-as in the T3000 menu system. You can attach it here or email to any of the many email address’s on the website.
