T3000 Webview Debugging
Here is the application and then pick the chrome button to go to the web app and no scan will happen. It brings up 2 dialogs asking for Port and Protocol (com8 and MODBUS_RS485) and hit refresh and nothing.
I don’t see a way to add a virtual device in the web app.
Could you please try the following:
  1. Double-click Tstat10 in the T3000 application and verify whether the inputs load correctly. Please also check and share the status shown there
  2. Refresh the web app after step 1. There should be a status bar at the bottom of the page. Please share a screenshot of it again
If the issue persists and the data still cannot be loaded, please provide remote access so that we can assist with further troubleshooting.
@qiaonuo thanks for some basic debugging last night. We saw that the COM8 that T3000 is using says in the debug log the message:
INFO t3_webview_api::lan_scan::serial: [lan_scan] serial COM8 scan failed: cannot open COM8: Access is denied. (os error 5)
So when I open the Web View, and refresh no devices show upon refresh and I have a T3000 and Tstat10 currently connected.
If I select TOOLS / Connect, then it prompts for the COM port and I enter COM8, (Is this correct, should it use the same port as T3000 without conflict, otherwise how does it use the same communication port that T3000 application is using?) Next, it prompts for Protocol and I enter MODBUS_RS485.
Please let me know the next steps as this is stopping me from trying the integrated AI tools.
t3-webview-api-dll.log (20.6 KB)
Please keep T3000’s current configuration as it is for now, so that it can load the device information.
Based on the log, we have made a fix and added a path for this situation: when T3000 loads data over RS485, the COM port is already in use — so we changed the WebView to load the data from T3000’s internal data instead.
Please try the following steps:
  1. Unzip the folder 26.1123.01.
  2. Back up:
    • C:\Program Files (x86)\T3000\ResourceFile\webview\www
    • C:\Program Files (x86)\T3000\t3_webview_api.dll
  3. Close T3000 (the DLL is in use while T3000 is running).
  4. Replace these files with the ones from 26.1123.01:
    • 26.1123.01\www → C:\Program Files (x86)\T3000\ResourceFile\webview\www
    • 26.1123.01\t3_webview_api.dll → C:\Program Files (x86)\T3000\t3_webview_api.dll
  5. Start T3000 again.
  6. Try it again. If the issue persists, please share remote access and I will continue investigating.
Here are a few screenshots. It finds the device, but can’t display any info from them. Here is a fresh log file.
t3-webview-api-dll.log (6.8 KB)
Please double-click the device in T3000 first so its information loads there — all data comes from T3000. Can you try that?
I finally set my default browser to Chrome, then had to refresh a few times and within the browser window did that as well and the data started synching. It seems to be working now, but having an issue with Claude writing the variables and it was starting from zero instead of var1 and not having success when it tried to write the variables back and had done VAR3, from the old value it downloaded, it had cleared all variables except 3 which it wrote back correctly.
Are you using the AI assistant to write the values back? If so, could you share a screenshot, or tell me which API is being used in the AI Chat panel? I will help check it — and please share the t3-webview-api-dll.log again.
There is also some runtime context at C:\Program Files (x86)\T3000\T3Web\ai-assistant — please share that with us as well.
Yes, was trying to use Claude to write to the web interface. I will find the logs. I didn’t commit any changes from Claude. I tried the csv export/import and it wrote values for the variable names correctly, but the units are messed up. Trying to write ºF and it would be heat/cool or close/open.
I then tried to change the UNITS manually and when I make a change, it would write all rows with the selected value.
There is no T3Web folder
t3-webview-api-dll.log (92.3 KB)
I changed tabs to get the screenshots above and now the units seem to change on the one I’m on, not all of them.There is something funny going on there and not sure I can trust it.
I also tried to use the MULTI-STATE and there is no interface that I see to enter these variables which are used for my run state of OFF/HEAT/COOL
If you want to try the local AI, please fill in the URL as shown below — it’s a local model, not the MCP URL.
I assume you are using Claude Desktop and have added the T3000 MCP server to it — is that correct?
Is it possible to share some conversation context from your Claude session, along with some screenshots of when you update the value from the web interface?
I’ll have to look into this further tomorrow
Chenbin will check in and fix at once.
We’ll have to ad you to the collaborators soon. This is where things are heading gentlemen. Once you get the workflow going with your agents and ours, this system will fly.
Chenbin will reply on the technical details.
We have fixed these issues and released a patch for them.
Copy each file from the 26.1125.01 folder to the path shown below:
26.1125.01\www → C:\Program Files (x86)\T3000\ResourceFile\webview\www
26.1125.01\t3_webview_api.dll → C:\Program Files (x86)\T3000\t3_webview_api.dll
26.1125.01\t3_webview_api.dll.exp → C:\Program Files (x86)\T3000\t3_webview_api.dll.exp
26.1125.01\t3_webview_api.dll.lib → C:\Program Files (x86)\T3000\t3_webview_api.dll.lib
Then restart T3000. When you retry the same steps, please share some screenshots along the way, and also the log files from the T3000 folder.
