Hi ,
just want to gain so knowledge on controller as a open source..
do i prog it using using some python software as conversion lib present .
like esp one .
how to remote update it using some other language any details on it ..
remote flashing .. any parser details for to get in the bootloader mode via Ethernet..
any python support other than t3000 quite outdated it looks ..
You can study the source code of our products here:
The controllers can be managed using any bacnet/modbus tools. You can use our T3000 for the inital configuring, the source code is here:
unable to find the specfic file that allow the user to update the controller via ethernet . LB controller for example .
As a fist step, try updating with T3000, you can do that by navigating to T3000 → help → check for updates → update firmware.
