I am brand new to the T3000 software. I just created/converted my first JSON file. I suspect the issue is with my file creation. Before I go down that rabbit hole I just wanted to verify. I click on the Webview graphic → File → Import → Import from a JSON file. If I have a properly configured JSON file will this work to import the file?
I dont’ think we’re that far along with our webview project but our crew will reply in more detail. Sounds like JSON support is something we’ll need to be adding soon.
Thank you for your response. Not a big deal, T3000 has plenty of features for me to dig into.
hi Maurice
I have a few schools that have some old Trane controls I’m looking at replacing one to see how it will work out i would like to talk to about this over phone were i can explain in detail what we have i can tell you some here now it is 15 ton package Hea pumps with two stage cooling three stages heat two are electric heat and the other is a boiler the boiler is primary the first stage on if is running and a call for heat on system and if the temperature isn’t cold enough for boiler to be on then heat Pump will run unit outside temp is 35 degree’s thanks
if you can help i was thinking of T3000 or if it will work please replay maybe we can talk about this dwayne.hammonds@xxxxxxxx
my information
Dwayne Hamonds
910-674-xxxx
For sure, we have many school board clients. I will call you today.
This is posted in the graphics topic so I can let you know that we’re continuing to develop and improve the graphics. We’re a bit late to the party but soon you can access the system from a browser directly. Next step we’re working on some 3D features.
Note: Not sure you should put your personal details there on the forum so obscuring that for you.
