Looking for directions on setting up the WI-FI on a T3-OEM. Not fining anything in the help file.
First connect over Rs485 and setup the WiFi credentials. Sorry about that, you’ll need to round up an RS485 if you don’t have one already.
Thank you! Entered my office SSID and Pass. The option tabs are partially hidden so I missed the config screen. LCD screen confirmed IP address was assigned, I then removed the USB-485. Tested DO’s in manual and confirmed working with audible relay click.
