Setting IP addresses etc
I am now trying to implement my T3-BB project, but am having trouble getting IP addresses etc set up correctly. I confess not having a good understanding of IP addresses .Previously I have been working with my single PC and the IP address allocation has been happening (by magic!) in the background, but I really need to understand it.
Two big changes from before is that
  1. I am working on a different local network - the router has IP address 192.168.0.1. Previously my router was 192.168.1.1
  2. I now have 2 x PCs running (mine and clients) - communicating with the same T3 controller. So the system configuration is as follows:
  • 2 x Win10 PCs
  • T3-BB controller
  • Weintek HMI
  • All connected on the same LAN switch. This local router connects to another (higher level) router which connects to the internet
After a week or so I plan to take my PC away and set up port-forwarding to allow remote access to the controller.
A month ago at home the T3 had a stable IP address 192.168.1.233 - regardless of how many times I stopped/started it. Today, when I first powered up driving from my PC with a different router, comms health was initially 0% (red), and “configuration window not available for this device”. I tried the “magnifier” scan icon and it seemed to go through the motions of a scan, but showed a blank screen of scan results. (By the way, the “DONE” button on the Settings window causes a hang-up)
The new router operates on subnet 0 unlike my home router which runs on subnet 1, so I guess the T3 had to learn to look on Subnet 0. Both routers use DHCP.
I dont know how it happened (that’s my point), but eventually I got a pop-up saying the IP address is wrong, so I accepted the suggested change to match IP addresses - and things started working with the T3BB. I still need to re-link the Weintek to the T3 - again - I expect this is an IP addressing issue also.
Although the “self-recognition” scheme is quite good, what I really would like to know is how to “force” the IP-Change pop-up to appear. For a while I was stuck being unable to open the configuration window to access communications settings.
Attached is a screenshot of my current settings window. The IP address shown - matches what’s on the T3 LCD screen.
Running T3000 on my PC with building view - when I hover over the T3-BB icon, the T3’s IP address is 192.168.0.243 (same as T3 LCD screen) and the PC IP address is 192.168.0.136.
When I hover over the Weintek HMI icon it reports HMI IP address of 192.168.1.217 and the PC IP address is 192.168.1.84. (as they were when I was at home - obviously wrong now).
I would like to “re-attach” the HMI, but I have forgotten how I did it originally. I think it may have been background magic again that I cannot replicate. I can see all my parameters in BACnet tools. Maybe it will happen by magic again if I can sort out the correct IP address for the HMI.
Running T3000 on the clients PC (there is no Weintek shown attached in building/tree view) Hovering over the T3BB icon, it reports the same IP address (192,168.0.243 for the T3BB, but of course the connected PC has 192.168.0.223. I understand that every connected device must have a unique IP address.
What does the “Change IP” button do exactly? What does the IP change to? Does it ask the router to allocate a new IP? It seems to go through a “reboot” process but did not change the IP address. Maybe the other PC being connected prevented a new IP address from being allocated.
I know my questions are basic, but the T3000 documentation/help is not helpful. - eg the screenshots are no longer current. In general the documentation is useful as a reminder of existing knowledge, not as initial learning
I dont remember how I got the Weintek attached to the T3 initially - I think it must have been “by magic” - some auto-detection thing.
I have done scans - The T3-BB can be found but not the Weintek - it still reports the wrong IP address. I am working on that with Weintek
Please check your router’s DHCP table to confirm which IP addresses have been assigned to each device. You can also use a free tool such as ”Advanced IP Scanner“ to quickly view all devices and their IPs on the network.
Also note that the “Change IP” button in T3000 is used to apply a manually entered static IP address. It will not request or change an IP assigned by DHCP.
This tool has saved us many times over the years, it checks for working/duplicate DHCP servers on your network.
