Hi everyone,
I’m integrating an PS-8-0-0 differential pressure sensor into a Modbus RTU network. The device only supports NONE parity, but there is no visible option to set EVEN parity — it seems locked to a default setting.
In my system, all Modbus devices are configured to EVEN parity, so I can’t communicate with this sensor properly.
Questions:
Is there a hidden register or service mode that allows changing the parity setting?
Has anyone successfully used this sensor in networks that require EVEN parity?
Any advice or workarounds would be appreciated!
Thanks in advance.
