A Beginners Step by Step Guide to Create Your Smart Home System with a Node-RED Dashboard GUI and trial-test IoT
Access your Raspberry Pi from anywhere, anytime .. connect to Temco controllers via Modbus or Bacnet.
Brief Overview.
This course will start with installing your Raspberry Pi (RPi) OS; specifying the required hardware equipment; then installing Node-RED (NR) and required nodes; creating a thermostat node flow to connect to a Modbus Temperature-Humidity Sensor and WiFi Smart Plug to automatically control your home Heating/Cooling and Lighting.
You will then create a Browser based NR Dashboard GUI. You will learn how to connect your Dashboard GUI to the Internet and to trial-test a Cloud connection to monitor and control your Smart Automated Home from any Internet connected device from anywhere, anytime. Ideal for holiday homes and second properties.
The Extra section will provide a sophisticated NR Flow (download) for Alerts and a trial-test of your email Alarms.
We will also discuss the exciting future potential of Node-RED, its growing use in commercial applications including corporations using it in conjunction with Artificial Intelligence (AI) for energy saving smart buildings and utility power supply Demand Response schemes.
