I know it’s bad form to use a GOTO or GOSUB command. They are to avoided at all cost but… I need some syntax or examples of putting multiple statements/commands between the THEN and the ELSE. I could eliminate all my GOSUB or GOTO commands if I knew how to do something like the following example. Other languages let you do something like:
100 IF this is true and this is true or that is true THEN
110 do this veeeeeerrrrrrryyyyyy long statement
120 do this too
130 do this also it might be a nested IF
140 REMcan’t put lines 110~130 on 1 line w/comma delimiters cuz theyd be too long
140 ELSE do this
150 ENDIF
I will just continue using a GOSUB at the end of line 100 and put lines 110~ 140 in it if that’s my only option. My goal is just to program as efficiently as possible. Any examples would be welcome. Maybe I am just ignorant on how to make program lines longer than 80 characters.
