IF Alternative?
Just checking…(I dont have hardware to test this on right now)
A typical simple IF statement is:
10 IF VAR1 AND VAR2 THEN VAR3 (all VARs are Boolean)
Can this also be written…?
20 VAR3 = VAR1 AND VAR2
10 IF VAR1 AND VAR2 AND VAR3 THEN do something here.
This might work but I’d rework it something clearer and easier for the next guy to maintain:
30 IF VAR1 AND VAR2 THEN START VAR3 ELSE STOP VAR3
I cannot have explained myself well enough…
I am wondering if it is possible to do simple logic-operations INSTEAD OF using an IF statement. I realise this is not suitable to achieve a complex result, but if the only reason for an IF-statement is to combine two variables into a third, I wonder if this is possible.
So my question is, can the statement:
10 IF VAR1 AND VAR2 THEN VAR3 = 1 ELSE VAR3 = 0
be replaced by the statement
10 VAR3 = VAR1 AND VAR2
This could be useful as a compact precursor to an IF statement with a large number of input conditions, eg
10 VAR6 = VAR1 AND VAR2 AND VAR3 AND VAR4 AND VAR5
20 IF VAR6 THEN [required outcome] ELSE [something else]
I am just not sure of the kind of logical operation described above is “allowed”.
I havent tried i before, why dont you give it a try and report back here.
I tried with three simple expressions
10 VAR1 = VAR2 AND VAR3
and
10 VAR1 = VAR2 OR VAR3
and
10 VAR1 = VAR2 AND NOT VAR3
VAR1,2,3 with Units 1 (Off/On)
VAR2 and VAR3 in Manual.
all expressions evaluated correctly.
These are equivalent to:
10 IF VAR2 AND VAR3 THEN VAR1 = 1 ELSE VAR1 = 0
10 IF VAR2 OR VAR3 THEN VAR1 = 1 ELSE VAR1 = 0
10 IF VAR2 AND NOT VAR3 THEN VAR1 = 1 ELSE VAR1 = 0
but much more compact in the program listing - although there is very little difference in memory used.
Of course this does not replace IF statement in all cases, but useful nevertheless. I see an important use in combining many inputs where a regular IF statement would overflow onto 2 lines.
I was a bit lazy with my reply, I admit. Thanks very much for confirming.
Just checking as the documentation is not perfectly clear…
Am I correct that in Boolean expressions the default order of execution within a single statement is NOT then OR then AND ??
I notice that T3000 usually removes parentheses but this seems to change the intention, eg in the part-statement
… ( VAR1 AND VAR2 ) OR VAR3…
I want to perform the (VAR1 AND VAR2) first and then OR that result with VAR3.
When I F2 ‘Send’ this, the parentheses are removed, but wont this result in
… VAR AND ( VAR2 OR VAR3 ) which is not what I intend ??
The order from top to bottom is:
NOT
AND
OR
My suggestion is keep it simple, make it easy for the next guy to maintain this 5-10 years down the road:
-One concept or function per line.
-Lines at the bottom will override lines further up in the program.
Thanks - I’m glad I checked - I had the order wrong
Still should confirm first, and my recommendation again is to steer away from such complex statements. Simpler programs will be easier to maintain later on.
